Just had maintenance done which included changing timing belt and water pump. Noticed a antifreeze smell in front of the car when I brought it home. The following day noted loss of fluid in the reservoir. Brought it back to the repair shop. They checked everything and did a pressure test plus 2 test drives but were unable to find a leak. Did change the change the cap on the radiator. Trailed antifreeze on my driveway and into the garage returning home from work today. No signs of overheating. Reservoir still has fluid but decreased in amount. No problems prior to the changing of the pump and belt. Any ideas at to the cause? Is it possible the new pump is defective?
Oct 8, 2009 at 1:22 PM
