2002 Honda Civic A/C not blowing cold air
100,000 MILES • 4 CYL • FWD • MANUAL
CLAY4U
when my A/C is turned on its not blowing cold air i tried putting feon in the low side but its full the compressor turns on but not getting any cold air to come out
Jun 11, 2008 at 3:40 PM
  • 31,937 POSTS
Hi there,
The first thing you should do is have the system pressures tested, this will give the tech a good idea as to what is going on, if you have added refrigerant, the system may be over pressurized and the hi pressure switch may be cutting the system out.
Mark (mhpautos)
Sep 23, 2019 at 4:40 AM
