2002 Honda Civic A/C Fan won't work
2002 HONDA CIVIC
100,000 MILES • 4 CYL • 2WD • MANUAL
CHIEFTAC2
My A/C, Heater fan won't work. I looked at the fuses and they all looked good.
Aug 14, 2009 at 1:54 PM
KHLOW2008
  • 41,814 POSTS
Hi Chieftac2,
Most probably the fan motor is bad. At fan motor connector, unplug and test for availability of voltage. If voltage is present, ground the other wire with connector plugged in and if motor does not work, the motor is bad.
Aug 18, 2009 at 1:45 PM
