My A/C, Heater fan won't work. I looked at the fuses and they all looked good.
Aug 14, 2009 at 6:54 AM
KHLOW2008
✓Experienced Mechanic
Hi Chieftac2,
Most probably the fan motor is bad. At fan motor connector, unplug and test for availability of voltage. If voltage is present, ground the other wire with connector plugged in and if motor does not work, the motor is bad.
