2002 Honda Civic Stalls While Driving
I have a 2002 Honda civic EX 1.7vtech engine and i've been having this problem for a while. The car Just turns off while driving. it happend like 5 months ago and i changedthe "cranshaft" something like that, and it stoped, now is happening again. but it only happends somethimes.i drove the car today and it didnt happend, but like 3 days ago the problem happend. Whats wrong, why is it doing that and how can i fix it?
Apr 28, 2007 at 1:11 PM
They probably replaced the crankshaft position sensor. It could be another sensor but it could be one of a number of other items. No check engine light on? It is hard to say be patient and it will manifest itself by getting worse and thus making it easy to diagnose.
Apr 30, 2007 at 3:13 AM
most likely the electrical part of the ignition switch. i'm almost 100% sure this is a recall item.
May 1, 2007 at 12:34 PM
Suggested Repair
Have the electrical portion of the ignition switch checked, including whether a recall applies. Also recheck the crankshaft position sensor and related sensors, and scan for codes if a check-engine light appears.
Conversation Summary
The owner of a 2002 Honda Civic EX reports that the engine intermittently shuts off while driving. A crankshaft-related part, likely the crankshaft position sensor, was replaced about five months earlier and the problem stopped, but it has returned occasionally. One expert says another sensor or other component could be involved and that diagnosis may be easier if the fault becomes more consistent. Another expert believes the electrical part of the ignition switch is the likely cause and may be covered by a recall.
