2001 Honda Civic Trunk Liner
WILLIAM DIVITCOFF
Interior problem
2001 Honda Civic
I want to install a cargo net which I bought from the dealer. How do I remove the plastic fasteners that hold the trunk liner in place located on the sides of the trunk. The net came as a kit with replacement fasteners that also have a hook to hold the net.
Thank You
Aug 7, 2008 at 7:01 AM
KHLOW2008
  • 41,812 POSTS
Hi William ,
If the plastic fasterners are of 1 piece type, you need to pull out. If it is 2 part type, push centre in wards and pull whole assy out. If it has a cross, use screwdriver to loosen and pull out clip.
Aug 10, 2008 at 3:59 AM
