2001 Honda Civic Steering, little bit of wobbling, front wh
97,000 MILES • 4 CYL • 2WD • MANUAL
NAGENDRA
I have honda 2001 civic lx. This car has few problems which are the steering is hard, there is a little bit of wobbling and one of the front wheel rim is bend. I want to how serious are these problems are and how much it costs to fix these problems.
Sep 26, 2010 at 8:14 AM
F4I_GUY
  • 3,302 POSTS
If the steering is hard, it's a power steering issue. Either you are low on vehicle, loose belt, etc.. it can ruin major steering components. So it is serious.
A bent rim will cause a steering wheel shake and over-time can cause excessive wear on front end components from all the vibrations.
Sep 26, 2010 at 11:07 AM
NAGENDRA
can you give an idea or range of how much it is going to take to fix these problems.................
Thanks
Sep 27, 2010 at 5:15 AM
