2001 Honda Civic Squealing noise from tranmission
RUSSELLDM
Noises problem
2001 Honda Civic 4 cyl Two Wheel Drive Automatic
I am getting a squealing noise from the transmission. Occurs only when the stick is in "D", and only in lower gears. Any ideas?
Aug 29, 2010 at 5:31 PM
  • 31,937 POSTS
here,
Thank you for the donation,
This sounds like a slippage problem, i would not be driving the carr very far as you may be doing more damage to nit, i would get t inspected by a transmission specialist as they will have all the special tooling required to do a full diagnosis on this, you may get some insight if you do a scan and see if there are any transmission unresolved fault codes, i would start here.
mark (mhpautos)
Aug 29, 2010 at 6:33 PM
