2001 Honda Civic sas light
88,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIKEVICKI4107
stays on. Is this okay? Also, just noticed that more often when adjusting the radio, the electrical fails and car goes off (including engine) for a split second and then restarts on its own. I turned off radio to see if it would do it. The car didn't go off but the electrical dimmed when using the auto locks to the doors. I was idling with the car running and the emergency brake on and when I would lock the doors, the brake light would dim and then come back to bright. Same thing when I would unlock doors. Is this and the SAS light on related? What type of repair place do I take my car to to be looked at for this problem. Thank you, Vicki
Jan 30, 2009 at 5:18 PM
DAVE H
  • 13,383 POSTS
most good repair shops could diagnose and repair these faults for you .. sounds like it may be an electrical fault on the battery/alternator systems !
Jan 31, 2009 at 4:35 AM
