2001 Honda Civic rIGHT FRONT WINDOW LIFT
2001 HONDA CIVIC
108,000 MILES • 4 CYL • FWD • AUTOMATIC
PARKVIEW
Fuse blown, had current to switch, replaced window motor and regulator. Window went up when plugged in switch with switch off. Blew fuse. Replaced window switch it did not blow but would not move window, could hear click when tried to raise or lower. Then it blew fuse. Replaced fuse again and will blow fuse when switch is plugged in and still off. Window is up tight. [img:185a670466]http://www.2carpros.com/forum/automotive_pictures/221203_general_1.jpg[/img:185a670466]
Jul 31, 2008 at 3:19 AM
KHLOW2008
  • 41,814 POSTS
Hi parkview,
Should be some shorting of wires. Check wire harness between door and body pillar.
Aug 1, 2008 at 10:52 PM
