2001 Honda Civic Radiator
17,800 MILES • 4 CYL • 2WD • MANUAL
GIAOLAI
My radiation is broken. I bought a new one. How to replace the radiator?
Oct 9, 2008 at 2:25 AM
SENGS
  • 5 POSTS
first drain the radiator by un screwing the plastic screw on the bottom of the radiator then take the two bracket off of the top of the radiator normally its a 10 mm disconnect all the holes then just sgueeze the radiator and the fan out then swap the fan over to the new one and put it back same way fill it up with antifreeze with the engine on to make sure it get to the whole system
Oct 14, 2008 at 4:09 AM
