2001 Honda Civic oil leak
114,000 MILES • 4 CYL • FWD • AUTOMATIC
MDNKGN
Have replaced oil cover gasket. But, have small amount of oil accumulating on top of the block at the left end of the cover just under the upside down "U" shaped attachement at the end of the cover.
Apr 28, 2008 at 9:23 AM
MASTERTECHTIM
  • 4,750 POSTS
when you replaced the valve cover gasket did you replace those end caps or put silicone on them? if not then thats what you need to do.
Apr 28, 2008 at 9:33 AM
MDNKGN
[quote:ee48c02b96="mastertechtim"]when you replaced the valve cover gasket did you replace those end caps or put silicone on them? if not then thats what you need to do.[/quote:ee48c02b96]
Will try that...thanks
Apr 28, 2008 at 11:38 AM
