2001 Honda Civic Lug Replacement
SNG
Tires and Wheels problem
2001 Honda Civic 4 cyl Front Wheel Drive Automatic
Replace Broken Lugs on Front Hubs
Sep 7, 2008 at 9:35 AM
BMRFIXIT
  • 19,053 POSTS
Raise and support vehicle
remove wheel
remove caliper assembly (suspend it using wire )
detach and remove two 6-mm disc retaining screws
remove rotor (u can install two 8x1.25x12mm bolts in existing holes)
know u can hammer the old stud off and or u can use a stud puller
Sep 7, 2008 at 12:09 PM
