Engine Performance problem
2001 Honda Civic 4 cyl Front Wheel Drive Manual
hi i have a 2002 honda civic ex 5 sp 1.7 l one dayi was driveing i went to 4000 rpms the car shut off on me and check engin light was on i went home and hooked up my code reader i got a code p1361 which is tdc sensor cam shaft position sensino i went the te dealer ship and got a new oem sensor went home pu the new sensor in the camshaft postion sensor which is tdc sensor i made sure the tiing was on top dead center on hte cam and on teh crank i startd the car up and did the idel warm up. when i first started the car up the rpm gauge went up nad hte check engin light flashed about 8 to 10 times i i could rev the car up to 4000rpm with no problem but then the check engin light stayed on and the car wouldnt got past 3000 rpms and the rpm gauge stoped working i need help and also replaced timeing belt tensior and crank shaft sensor to
Jul 25, 2010 at 4:28 AM
