2001 Honda Civic High Beams
119,000 MILES • 4 CYL • FWD • AUTOMATIC
DREOBRDR14
I'm having trouble with getting my high beams to work. My flood lights are just fine but whether i set my high beams on or just flash them all it does is turn my headlights off completely. Would this be a fuse problem?? Thanks
Mar 10, 2009 at 8:33 PM
KHLOW2008
  • 41,812 POSTS
Hi dreobrdr14,
High and low beams uses the same fuses so should not be a fuse problem.
If the dash high beam indicator is showing, then the bulbs are fused.
Check for power supply to Red/Blue wire at headlight switch and if available, grounding the wire should have the headlight high beams working. That would mean a bad headlight switch or bad grounds.
Mar 6, 2021 at 9:17 AM
