2001 Honda Civic hesitatation
104,500 MILES • 4 CYL • 2WD • AUTOMATIC
GIZMO0706
I have a 2001 Honda Civic with 104000 miles. After a cold start the car hesitates when shifting from 1st to second gear. Pushing the accelerator harder doesnt' help. I have to let off the accelerator and then after it will accelerate and runs fine. I thought maybe it was the fuel filter but the honda dealer said that there is no fuel filter to change. What do you think?
thanks
Jul 10, 2008 at 10:38 AM
KHLOW2008
  • 41,812 POSTS
Hi gizmo0706,
I don't think it is the fuel filter.
Is the check engine light showing?
I would suspect the Throttle Position Sensor or a faulty O2 sensor. It could be the linear solenoid or a sticking shift control valve. Maybe a ATF fluid change might help.
Jul 11, 2008 at 4:01 AM
