2001 Honda Civic Front Lights
120,000 MILES • 4 CYL • FWD • AUTOMATIC
GABODFMX
I have a problem with low beam front lamps. Suddenly the low beam didn´t work any more. I´ve tried to check the fuse but I could not found them. The high beam is working.
What can I do to solve this. I´ve change the bulbs too but that was not the problem.
Jun 3, 2008 at 5:42 AM
KHLOW2008
  • 41,812 POSTS
Hi gabodfmx,
The fuses are in the under fuse box.
Both left and right uses separate fuses.
Since both are not working, you might have a switch problem.
Jun 4, 2008 at 4:03 AM
