2001 Honda Civic Errors everywhere...
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
SONYADLC
I had recently replaced my thermostat 4 months ago, then on a road trip to Arizona, it wouldn't stop over heating. It gave no faulty signs on the computer. when I came back to California, the problem stopped, until last week. It came back and I have to drive with my air conditioner blasting or it will overheat. It will claim it's overheating even when the heater is on. The gadge will quickly jump, and then once the air conditioner is blasting, it quickly falls. It only does this as I drive, so when I take it to a mechanic it will not do it immediately.
The battery is new too, just replaced in january this year.
I thought the air conditioner thing was something I could bare with until suddenly all of the electronics in the car will shut off, but the engine still runs. It would stop for the first two lights until I enter a freeway, when I can accelerate and the problem seems to cease, no matter how many stops I make on that trip. Prior to accelerating, the check engine light will come on, but once accelerated, it turns off.
Now that I feel like I drive a terrorized vechicle from the movie Speed, at 4k RPM, the car seems to choke (ie becomes jumpy when giving it gas). Not until it declerates to below 3.5k, it drives normal.
Dec 4, 2009 at 6:18 AM
KHLOW2008
  • 41,812 POSTS
Hi sonyadlc,
Do you have coolant losses issues?
When overheating occurred, did you check if the cooling fans were working?
From the symptoms, it seems there is a problem with power supply to the system and it could be a bad connection somewhere that is intermittently failing.
There was a safety recall for ignitions switches and you can call the nearest dealership to enquire if your vehicle falls under the category.
Dec 5, 2009 at 5:31 AM
