2001 Honda Civic Check engine- too lean
2001 HONDA CIVIC
53,245 MILES • 4 CYL • FWD • AUTOMATIC
KOLYA18
I'm having a problem! My check engine came on and the car is reading too lean! I feel there is loss of acceleration and when gas gauge goes below quarter the car starts to stall! Please tell me what the problem could be! I already checked the spark plugs and put injector cleaner in the gas!! Thanks
Jul 29, 2009 at 8:48 AM
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
Jul 29, 2009 at 8:51 AM
