2001 Honda Civic Check Engine Light/ECU Problem?
80,000 MILES • 4 CYL • FWD • MANUAL
COLORADOHONDA
I own a 2001 honda civic, and sometimes when i drive my car my check engine light turns on, and when it turns on i can't go over 4,000 rpms, when i try it sounds like im hitting my rev limiter, but if u turn my car off and turn it back on then it runs fine, can u please help me with this i haven't found anybody who know how to fix it.
Jul 11, 2008 at 7:19 AM
KHLOW2008
  • 41,812 POSTS
Hi coloradohonda,
When the CEL comes on, there is something wrong with the engine management system.
Get a scan dome to find out if any codes are stored in the ECM memory.
Nobody would be able to help you fix it without knowing the error code.
Jul 12, 2008 at 1:05 AM
COLORADOHONDA
I finally went to get my check engine light looked at because it went on again, and they printed me out a paper that said:
Global OBDII
DTC (Codes)
P1259
Manufacturer Contrl
Fuel Air Metering
I have no idea what that means though. can you help me please.
Jul 26, 2008 at 12:35 PM
