Hi rickyashby,
The symptoms described shows that the idling is erractic causing the problem.
Possible causes.
1. Low idling speed, You need to clean the throttle body and Intake Air Control valve.
2. Valve clearance too tight resulting in valve leakages and poor idling.
3. Uneven compression among the cylinders, do a compression test to find out.
SPONSORED LINKS
Friday, October 17th, 2008 AT 12:22 PM
