2001 Honda Civic Car A/C Not Working
179,000 MILES • 4 CYL • FWD • MANUAL
ANWARRANA7
My Honda Civic 2001 a/c not working if car is not is running. I means if the car stop on traffic light or stuck in traffic jam. the does'nt work and only air coming thru blower. but when car get in running cool air start coming? There is not freon lickage. Please advise the reason?
Apr 28, 2009 at 7:05 PM
ATKAPARKING
  • 64 POSTS
When you are driving, your motor is revving higher than at idle and your a/c works better. Possible causes are: Loose a/c belt, low a/c charge, loose or worn out a/c clutch. Some of these you can check yourself--there is also an a/c sight glass on these systems, very tiny, usually on top of the dryer. With your a/c on at idle, if you see little bubbles in the sight glass, your system is low on charge. Good luck.
Sep 23, 2019 at 4:44 AM
