2001 Honda Civic Pulls Right and Shakes
JULIE MEYER
Why would my 2001 Honda Civic with 70,000 miles and an automatic transmission pull to the right and shake when I drive it?
Jun 25, 2007 at 3:21 AM
BRUCE HUNT
  • 3,754 POSTS
Ask yourself if you have hit anything including a rail crossing or pothole. Then consider looking at tire pressure to make sure they are at the recommended pressure. Next please have the tires rotated to see if that helps as you could have a bad tire (ie cords are seperating) and finally - alignment time.
Jun 25, 2007 at 4:29 AM
Suggested Repair
Check for recent impact damage, verify tire pressures, rotate the tires to isolate a bad tire with separating cords, and then have the alignment checked.
Conversation Summary
The owner of a 2001 Honda Civic with 70,000 miles and an automatic transmission reports that it pulls to the right and shakes while driving. The expert advises checking for impact from a pothole or rail crossing, verifying tire pressure, rotating the tires to identify a bad tire, and then getting an alignment.
