Temperature needle rises to red zone?
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEY549
Needle rises to red zone. Rad and fan ok. Thermostat was changed 9 months ago. When putting heat on it lowers needle. Is the problem a sensor or the thermostat?
Aug 5, 2008 at 11:58 PM
SQM
  • 6,383 POSTS
It is possible to have the thermostat failed at the stuck closed position, which is triggering the engine to overheat.
Another possibility is that the water pump is not circulating coolant properly, which could be due to a bad impeller.
If the thermostat is stuck closed, you will have a significant temperature difference between the upper and lower radiator hose, when the engine is at operating temperature or above.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Here is a helpful guide on water pump:
https://www.2carpros.com/articles/water-pump-replacement
Feb 1, 2022 at 2:31 PM
