2000 Honda Civic po401
182,365 MILES • 4 CYL • FWD • AUTOMATIC
TALISAIN
egr insuficient fllow.i did what you told me to clean the port at the intake manifold.i use a wire cable. about 12 inches long with brake cleaner,then blow it with compress air. still the same check engine light still showing after a while of driving, car due for smog check. honda civic hx. help.
Sep 6, 2010 at 5:20 PM
  • 75,988 POSTS
HI talisain, Welcome to 2carpros and TY for the donation
Diagnostic Trouble Code (DTC) P0401:
Insufficient flow in the Exhaust Gas Recirculation (EGR) system.
Its either a clogged EGR valve or its defective to include a clogged intake port that will caused this insufficient flow
Sep 6, 2010 at 7:04 PM
