2000 Honda Civic oxygen sensor
152,000 MILES • 4 CYL • 2WD • AUTOMATIC
OGDEN3NC
I was informed by a mechanic that the check engine light on my 2000 Honda Civic is on due to a failing oxygen sensor. I want to know how hard it is to replace an oxygen censor myself, and if you had instructions on how to do this.
Apr 10, 2008 at 12:03 AM
BRUCE HUNT
  • 3,754 POSTS
First of all you need to know which of the two O2 sensors needs to be replaced. After that you need to purchase a new sensor and Do Not get a universal sensor. Get a direct replacement. I cut the wires off of the old one and slip deep socket over it and remove the old one. There is a special socket/wrench for this. The new one i tighten with an open end wrench. Route the wires to the connection and you are set. You need to reset the computer codes and you should be off and running.
Good luck
Apr 10, 2008 at 7:11 AM
