2000 Honda Civic O2 sensor
120,000 MILES • 4 CYL • FWD • MANUAL
RIDOLFI
when 02 sensor dosn't work what does the engine do.
and does the sevice engine light come one.does it
efect ideling of the engine.
May 3, 2008 at 2:43 PM
ROB2008
  • 258 POSTS
It is the primary measurement device for the fuel control computer in your car to know if the engine is too rich or too lean. The O2 sensor is active anytime it is hot enough, but the computer only uses this information in the closed loop mode. Closed loop is the operating mode where all engine control sensors including
the Oxygen sensor are used to get best fuel economy, lowest emissions, and good power and yes the check engine light usually comes on .
-Rob
May 3, 2008 at 2:55 PM
SINIXOTH
I’m not as sure with a manual because I have an auto but the first one senses the air pressure to give the computer the accurate numbers for fuel and all that, and the second one measures the effectiveness of the cat by the change in pressure. So, the first one will make you run poorly, second doesn’t seem to matter but I also have headers and no cat. Both will turn on the check engine light.
Dec 9, 2021 at 8:02 PM
SQM
  • 6,383 POSTS
The oxygen sensors job is to measure the oxygen required to burn any fuel remaining in the exhaust stream and relay that information back to the computer PCM (Powertrain Control Module) where it is compared with other live information so that adjustments can be made to maximize fuel efficiency and power via proper air-fuel mixture and ignition timing in the engine.
The oxygen sensor does this by chemical reaction inside the sensor itself.
Oxygen sensor can impact the fuel efficiency of a vehicle negatively if it is not functioning properly.
Here is a helpful guide on Oxygen sensors:
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
Depending on the scenario it can affect the engine idle if the mixture is too rich or too lean.
Faulty oxygen sensor will trigger check engine light. And by scanning the vehicle for trouble codes it can help determine the issue.
I have attached diagrams for oxygen sensor location and replacement procedure below.
Dec 10, 2021 at 2:13 AM
