2000 Honda Civic Humming Noise / Proportional to Speed
2000 HONDA CIVIC
110,000 MILES • 4 CYL • 2WD • MANUAL
SINTHETIQ
As I increase the speed when driving past 20mph, there is a loud, very noticable humming noise. The tires are new. The noise goes away when I veer/turn towards the right (passenger side). However, it comes right back when I straighten out. I'm guessing it is the wheel-bearing, but cannot pinpoint where it is coming from. What can I expect to pay for repairs and what else could possibly be wrong? Thanks!
Jan 1, 2008 at 11:27 AM
TOPGUN1226
  • 29 POSTS
You may need an alignment. When you replaced your tires, did you previously have an irregular wear pattern? This could hint that it's not your driving style, but perhaps a misaligned axle.
Not sure how long you've had the tires, you just said new - but you may want to do a tire rotation next time you get a lube & filter, that may help.
Jan 7, 2008 at 5:14 AM
MASTERTECHTIM
  • 4,750 POSTS
you definately have a bad bearing. approx cost to repair is $250. not an easy do it yourself job unless you have a hydraulic press and you know how to use it.
Jan 7, 2008 at 5:22 AM
