2000 Honda Civic Hub assembly
113,000 MILES • 4 CYL • FWD • AUTOMATIC
RALPH OCASIO
Is there a special tool rquired to remove the hub assembly. If not how do I aquire enough clearance to replace the lug nut studs. I have removed the caliper, rotor, center shaft nut and I still can't get the hub off.
Thanks,
Ralph
Jun 26, 2008 at 8:19 AM
KHLOW2008
  • 41,812 POSTS
Hi Ralph Ocasio,
You need a hub puller which you attach to the studs to pull it out by hammering outwards.
Jun 27, 2008 at 4:12 AM
