2000 Honda Civic Park Noise and Fuel Use
SAMJ
I just bought a 2000 honda civic (auto trans.) recently with 79000 miles. The problem i'm having is that whenever i shift into park i hear a strange sound like engine consuming gas, what could be the problem? Also, im getting a really bad gas consumption (like 6.5L/100KM- city driving). Any advice is greatly appreciated. thanks in advance
Mar 8, 2006 at 2:02 PM
BRUCE HUNT
  • 3,754 POSTS
Your terminology has be miffed a bit, but try this for size. The extra consumption of fuel is best looked at with looking at a tune-up. Pull a plug and look at it. Look at the exhaust pipe. If they are black in color, which I assume they will be, you need to look in to a tune-up. check the air filter and make sure the timing is correct. I assume that no check engine lights are on so start with a tune.
Mar 9, 2006 at 5:12 AM
Suggested Repair
Start with a tune-up. Inspect a spark plug and the exhaust pipe for black deposits, check the air filter, and verify ignition timing is correct, assuming no check engine light is on.
Conversation Summary
The owner of a 2000 Honda Civic automatic with 79,000 miles reports a strange sound when shifting into park that sounds like the engine consuming gas, plus poor city fuel economy of about 6.5 L/100 km. The expert recommends starting with a tune-up: inspect the spark plugs and exhaust for black deposits, check the air filter, and confirm timing is correct if no check engine light is on.
