2000 Honda Civic Fluid Leak
2000 HONDA CIVIC
85,000 MILES • 4 CYL • 4WD • AUTOMATIC
RAM.VISION207
How much does it cost to replace a Master Cylinder if the fluid is leaking?
How to do a manually check if the Fluid is leaking from the master cylinder?
Jul 24, 2009 at 2:48 PM
F4I_GUY
  • 3,302 POSTS
Pull the master cylinder off the brake booster, if the seal on the rear is leaking it must be replaced.
Cost of replacement is about $100 for the cylinder (if not cheaper) and about 1-1.2h labour
Jul 25, 2009 at 12:30 AM
RAM.VISION207
Thank you so much.
It will help.
Jul 25, 2009 at 1:41 AM
