2000 Honda Civic Fan Control Dial problem; clock light not
2000 HONDA CIVIC
62,600 MILES • 4 CYL • FWD • AUTOMATIC
HONDA CIVIC OWNER
The fan control dial on my Honda has stopped working at levels I and II, and only works on levels III and IV. Is it likely to be a costly job to have it repaired in view of the labour involved?
Also, the clock light has gone out - I can't see any easy way to get at the clock lightbulb - any advice?
Jul 16, 2010 at 9:47 AM
KHLOW2008
  • 41,814 POSTS
Hi Honda Civic owner,
The fan motor 1st and 2nd speed not functiong should be due to a faulty power resistor. Our database do not have any listing of the codst so you need to check with your local parts store. The labor time for replacement is 0.7 hour.
As to the clock back ground light, the clock has to be removed which entails removal of the panel.
Jul 17, 2010 at 9:06 PM
