2000 Honda Civic Engine trouble
2000 HONDA CIVIC
13,000 MILES • 4 CYL • 2WD • MANUAL
KLGOMEZ
I swapped the engine out of a 1996 Honda Civic and put it in my 2000 Honda Civic. I'm not getting fire to the plugs or fuel to the engine. What should I check or do?
Apr 20, 2009 at 8:26 AM
F4I_GUY
  • 3,302 POSTS
Which distributor are you using? You can't put an obd2a distributor into an obd2b harness connector, so I assume you used the 2000 civic's distributor?
Apr 20, 2009 at 10:49 AM
KLGOMEZ
I used the 96 distributor and the wire harness & PCM from the 96. Should I use the fuse box under the hood from the 96? There's no place to plug in the fuse box plug into the PCM so I'm wondering if I should use the 96 fuse box and wire harness.
Apr 20, 2009 at 1:03 PM
F4I_GUY
  • 3,302 POSTS
What you will have to do is use the OBD2B harness (the 2000 civic). You will also have to use the obd2b ECU, alternator and distributor since those two items have different harness clips on them.
Apr 21, 2009 at 10:39 AM
KLGOMEZ
if i use the wire harness and ecu from the 2000 then the vtech will not work and that was the whole point for the swap. i have to use the wire harness and ecu frome the 96 in order for the vtech to work. do i need the use the fuse box under the hood from the 96?
Apr 22, 2009 at 12:04 AM
F4I_GUY
  • 3,302 POSTS
Why do you say v-tec will not work?
Apr 22, 2009 at 9:36 AM
KLGOMEZ
I was told by a Honda mechanic that I needed everything electrical from the 96 and the fuse box. Please explain why you think it will work without the 96 fuse box.
Apr 25, 2009 at 4:39 AM
F4I_GUY
  • 3,302 POSTS
Like I have already stated.
Use the obd2b engine harness, distributor, alternator and ECU and everything will be fine.
If you find any harness clips that don't fit onto the appropriate sensor tell me which sensor it is.
Apr 25, 2009 at 12:35 PM
