I just changed the air filter, oil filter, gas filter, and the 4 sparkplugs. Engine was timed also correctly, and the car works perfectly. Except: Whenever I go refill my tank of gasoline, and start my car again, I need to pump continually the gas pedal (or start running the engine right away) in order for the motor to keep going, otherwise it stalls. I need to make the car run a bit before the pressure seem to be back in the fuel system.
Is my fuel pump dead, or my gas lines glugged up with dirt? The old fuel filter was terribly dirty.
Thanks
Hugues
Thanks
Hugues
Apr 29, 2008 at 5:19 PM
