I have engine light coming on after engine temp raises up to normal (like driving 15min after starting up) . then, goes off when i start it up again. And coming up again few mins after driving( normal temp).
so i assumed o2 sensor then,i jacked up and looked at it.
then, I found just unplugged second o2 sensor and I didnt see primary o2 sensor. The hole for sensor on exhaust pipe was just capped. (it has oem Sir catback with itr muffler and magnaflow high flow cat)
then, i was Just curious for primary sensor. so i try to find the connector from engine bay to install new one since it was just missing. then i couldn't find. As per Service manual , It should have it though. I dont really know well about ecm wiring, though.
ps. i checked with obd2 code reader, but it didnt show any code, just said read forever..
Aug 15, 2009 at 6:21 AM
