2000 Honda Civic door locks stays lock
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
DD1ATVINSM
I started with my windows not going back up, my windows are manual. I dismantled the door panel, and was able to force the window back up and put the panel back. Snapped back the power lock connector and tested it. The lock would go up and back down to lock.
I can't even manually unlock the door. I have to unlock using the power switch and open the door before it goes back down.
How do I fix this?
Aug 26, 2008 at 3:43 AM
KHLOW2008
  • 41,812 POSTS
Hi dd1atvinsm,
The driver door has a lock/unlock switch and it seems to be stuck in the locked position. You need to remove the panel to get at it.
Aug 27, 2008 at 3:06 AM
