2000 Honda Civic distributor
RANGER714
Engine Mechanical problem
2000 Honda Civic 4 cyl Front Wheel Drive Automatic
HOW CAN YOU TELL IF THE DISTRIBUTOR IS BAD?THAT SEEMS TO BE THE ADVICE I HAVE RECEIVED,THAT I SHOULD TRY REPLACING THE DISTRIBUTOR.
May 29, 2010 at 4:54 PM
KHLOW2008
  • 41,812 POSTS
Hi RANGER714,
The distributor can be tsted. Check the ignition coil resistance and power supplt to it.
The sensors can be tested as well
May 30, 2010 at 6:03 AM
