2000 Honda Civic Cruise Control
103,000 MILES • 4 CYL • 2WD • MANUAL
JMTWOOSTER
Our cruise control light comes on but the cruise control does not engage. Mechanic said the cause was the cruise control servo actuator. Happened right after we had a timing belt & water pump changed. Could it be something they did? Also, where is it located on the Honda--could we visually see if vacuum line or servo are intact? And, is it normal for servo to go bad after just 103,000miles?
Dec 26, 2007 at 8:26 AM
TOPGUN1226
  • 29 POSTS
I think if you noticed this happened immediately after the timing belt fix, you may be on to something.
Jan 7, 2008 at 5:15 AM
