I recently had an issue with my 2000 Honda Civic EX. The car would not start, it would not crank over. I replaced the spark plugs, distributor (along with cap and rotor), spark plugs wire, and the fuel filter. My intial thought was that the fuel filter was clogged. While replacing the fuel filter, I made sure the fuel pump was pumping gas to the filter (and it was). After replacing the fuel filter, the car still did not start. I then replaced the distributor along with the cap and rotor. After replacing the distributor, the car finally started but it was rough and the check engine light came on. I took the car to Advance auto parts and they told me the cylinder #1 was misfiring P0301. The salesman suggested I start by replacing the spark plugs and wire. I replaced the spark plugs and wires. The car does run smoother but the check engine light is still on. I took it back to Advance auto parts and the salesman told me "The check engine light needs to be reset after replacing the spark plugs and wires." So my question is "Is it typical to reset the check engine light after replacing the spark plugs and wires or with the car reset it self?" Please let me know.
Feb 8, 2008 at 6:08 AM
