2000 Honda Civic Brake sensor
157,000 MILES • 4 CYL • AWD • AUTOMATIC
GMGOFF
My back brakes continue to squick. Changed brakes and rotors. It still make noise. I was told the brake sensor is probably damage. What is the brake sensor? What is the cost to repairt?
Aug 15, 2008 at 12:44 AM
2CARPRO JACK
  • 11,533 POSTS
The brake sensor? there are sensors on the pads the squeek when they contact the rotor, but they should only do that when worn down, not new. What kind of pads did you use? Hondas will make noise if you use cheap pads or rotors. Does that car haev a seperate e-brake assembly? if so be sure the shoes for it are in good shape
Aug 15, 2008 at 12:49 AM
