2000 Honda Civic alternator isn't charging
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAN SADLO
only getting 12.65 volts on the battery terminal with
engine on ,high beam ,heater on.
when I disconect output wire from alternator I get 16.5VDC when I put it back it is loading down to 12.65VDC. Replaced ELD in the fuse box no help.
any help would be apriciated.
Feb 9, 2008 at 4:12 PM
  • 75,988 POSTS
12.6 is not enough -its not charging BTW its a bad idea to remove the alty's output wire.
Your regulator is gone its not controlling the field winding-when the regulator sees resistances it will lower the output and vice versus.
Feb 9, 2008 at 4:33 PM
