2000 Honda Civic a/c problems
2000 HONDA CIVIC
120,000 MILES • 4 CYL • FWD • MANUAL
MICHAELSCIVIC
The problem started at high RPMs. I would get a loud screeching sound.....finally the armature plate froze up and sparks came out......I replaced the entire clutch kit and it does the same thing....soon as you turn the A/C on it screeches and the armature plate is not turning...no cold air is coming out....Is the compressor bad?
Aug 1, 2008 at 2:33 AM
KHLOW2008
  • 41,814 POSTS
Hi michaelscivic,
Did you test if the compressor is seized?
Aug 1, 2008 at 11:55 PM
