2000 Honda Civic A/C Issue
90,000 MILES • 4 CYL • 2WD • MANUAL
V.GREENEJR
After my a/c has been on for a while, when I come to stops my rpms drop really low and I begin to hear a clicking sound. The car seems as though it is about to shut off; but if you turn the a/c off everything is fine. I'm not sure what the problem is and how to resolve it.
Jul 23, 2009 at 5:21 PM
KHLOW2008
  • 41,812 POSTS
Hi v.greenejr,
You have a problem with the idling circuit and that is causing the AC compressor to cut in and out. The compressor requires a minimum idling rpm to stay engaged.
I would suggest cleaning the throttle body, IAC and idle adjust screw to stabilise the idling speed after it has warmed up.
Jul 25, 2009 at 7:36 PM
