1999 Honda Civic Vacuum leak
1999 HONDA CIVIC
74,000 MILES • 4 CYL • FWD • MANUAL
PAUL90
Hello mate,
I just have some questions, how do you check and sort out vacuum leak at the throttle body? low cylinder compression? blocked fuel injector system?
Thanks for your help.
Jan 5, 2009 at 7:09 PM
  • 31,937 POSTS
Hi there,
If you have all these problems you should do the serious one first and that is the low comps, what you will need to do is re set the valve clearances, and do a comp test, if you have a low comp re do the test with a small amount of engine oil in the cylinder as this will temp seal the rings, and if the comps come up the rings are a problem if not you will have a valve problem, start here and report back your findings.
mark (mhpautos)
Jan 5, 2009 at 7:27 PM
