1999 Honda Civic TUNE-UP
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
MSHELTON1956
How much should it cost to do a engine tune up which includes the ignition coil, wire, plugs, distributor cap and rotor and fuel filter.
Thanks...
Mar 3, 2009 at 8:26 AM
F4I_GUY
  • 3,302 POSTS
Ignition coil is not a tune-up item.
You should be doing, PCV, fuel filter, cap, rotor, wires, plugs, all required fluids and possibly a valve adjustment.
Labour rate for the fuel filter is 0.5, the ignition tune-up will be about 1.0hr labour.
Mar 3, 2009 at 9:37 AM
