1999 Honda Civic rear passenger side door wont lock
150,000 MILES • 4 CYL • FWD • MANUAL
MJTANDAYU
i had a 1999 honda civic lx, the door on the rear, passenger side wont lock, i've already tried locking it manually but still when you open it from the outside it would still get open, even if i engaged the anti-theft lock, still it would open up. another problem is about my auto locking system using the anti-theft system, it function normally on all door except on the driver side lock, meaning the other three doors would lock up ( except the door on the rear passenger side, but the locking tab inside the car would go down if the anti theft is engaged) except the driver side door. hope you can help me with my problems, thanks and more power to your website.
Oct 24, 2008 at 2:59 AM
KHLOW2008
  • 41,812 POSTS
Hi mjtandayu,
You have 2 separate poblems here.
1. Rear passenger door lock actuator link to latch assy is either detached or worn resulting in the latch nort being locked. You need to remove the door panel to check it out.
2. Driver door lock actuator is faulty.
Nov 10, 2008 at 5:35 AM
