1999 Honda Civic Power Windos on track won't roll up all th
PSTEWART2135
Electrical problem
1999 Honda Civic 4 cyl Front Wheel Drive Manual
Can you please send me information how I can roll up my window all the way up just shy about an inch from the top
Oct 6, 2008 at 3:46 AM
KHLOW2008
  • 41,812 POSTS
Hi pstewart2135,
If you can manually push the door glass up to top and there is slack, the regulator is faulty and needs to be replaced.
If it cannot be done, then the runchannel is bad and restricting the door glass movement. If using your hand to assist works, you can try spraying some silicone or wax based lubricants to the runchannel at the front end near side mirrors. If it works, it would only be temporary, you need to replace the runchannel to solve the problem.
Oct 15, 2008 at 7:19 AM
