1999 Honda Civic Oil leak or burning?
228,488 MILES • 4 CYL • 2WD • AUTOMATIC
DODSTER
When getting my oil changed today I was told that I may have a front main seal leak. At the last two oil changes the oil level was low. The car has been maintained and never needed repair. If it is the front main seal, what will the cost be?
Oct 18, 2008 at 4:53 PM
AUTOFIXER2
  • 29 POSTS
it would help us to find out specifically where the oil is leaking from. you're at the mileage when the crankshaft seal needs replacing. however. the oil may be leaking from the timing cover gasket or the oil pan gasket etc. the crank seal isn't a great big job. to quote you on the repair wouldn't be fair to you as most garages have different labor rates.
Oct 19, 2008 at 3:40 AM
