I've had my 1999 Honda Civic EX sine new and after changing the oil about 200 miles ago I noticed oil in m driveway. I rechecked the filter and oil pan bolt and all looked tight and dry. After looking around for a while I noticed that there was a drop of engine oil coming out from under the distributor. I checked the distributor bolts and they were tight. I looked on line and noticed there is a seal that can be replaced and an 'O' ring. My question is how easy is it to remove the distributor and change the gasket and 'O' ring? Do I need any special tools and will I have to re-do the timing when I place the distributor back in place? Thanking you in advance for your help and assistance. Any tips would be appreciated.
Jan 20, 2008 at 9:20 AM
