1999 Honda Civic Oil Leak...
CHECKTHEMEANING10
  • 6 POSTS
Engine Performance problem
1999 Honda Civic 4 cyl Two Wheel Drive Manual 133K miles
I have a 99 Honda Civic EX Coupe that leaks oil. At first I assumed it was the gaskets because I took it to a lube shop and they said that's where it was coming from. Changed the gasket and then it kept leaking. It's coming from the top of the engine where the pistons are..but in the back where some little metal squarish type thing with a round cylinder meets with the metal part.
My mechanic has tried sealing it with silicone. And it hasn't worked. He says it is called the v-tec valve but I've looked for it at autozone, o reillys the likes but they never heard of it. It slowly leaks and I can't figure out where it is. Thanks.
Feb 9, 2010 at 10:15 AM
  • 110,248 POSTS
Have you contacted the dealer for the part?
Feb 9, 2010 at 1:35 PM
CHECKTHEMEANING10
  • 6 POSTS
No I haven't been to the dealer yet. I was just wondering if anyone knows the name. I'm sure when I go the dealer will tell me but who knows. They may charge me up the yin yang to fix it.
Feb 9, 2010 at 2:39 PM
  • 110,248 POSTS
Yes, I agree. Is it possible for you to take a picture of the part and upload it for me to see?
Thanks,
Feb 9, 2010 at 3:01 PM
CHECKTHEMEANING10
  • 6 POSTS
Yes sorry I've been busy with school and other such things. I will post a picture tomorrow because it's dark tonight and I want the light to be good. Hopefully this topic hasn't fallen off where no one will see it.
Feb 23, 2010 at 1:26 PM
  • 110,248 POSTS
I'll be waiting for the picture.
Feb 23, 2010 at 10:29 PM
CHECKTHEMEANING10
  • 6 POSTS
Okay here is the picture...it's where my finger it's pointing. The thing with the little cylinder on top is leaking oil. I think it needs the gasket but I don't know the name of the part to put the gasket in.
https://images.2carpros.com/forum/automotive_pictures/479595_CIMG0003_1.jpg
https://images.2carpros.com/forum/automotive_pictures/479595_CIMG0005_1.jpg
Okay the second one is the closer picture of it. It screws onto the bigger part with three screws. I need to know the name of that whole part because I can't find the gasket without the name. Thanks in advance.
Feb 24, 2010 at 9:24 AM
CHECKTHEMEANING10
  • 6 POSTS
Here's a closer look at it.
https://images.2carpros.com/forum/automotive_pictures/479595_CIMG0001_1.jpg
https://images.2carpros.com/forum/automotive_pictures/479595_CIMG0002_1.jpg
Feb 25, 2010 at 4:29 AM
CHECKTHEMEANING10
  • 6 POSTS
Is there anyone that can help answer this question? I'm really wanting to get this fixed on my car. Thanks in advance.
Mar 2, 2010 at 9:36 AM
ROTARYMAN12A
The overall assembly is the "lock up VTEC solenoid valve and oil pressure switch", and it is also referred to as the "cam adjust solenoid."
The top part, help on by the three bolts, is the "solenoid." The cylinder is the "cam adjust solenoid."
There are several orings and seals, so you will need to pinpoint the leak and then head off to the dealer to use their parts diagram to find the right one.
Jul 10, 2010 at 7:22 AM
